SPOT Satellite Messenger vs Fast Find PLB
pupluv
Nov 11, 2007
90
- - wilmington, ca
I'm trying to decide between a SPOT Satellite Messenger and a Fast Find PLB as a backup emergency notification device. I do coastal cruising out of LA (Marina del Rey) and sail both south to Baja and north to Conception.
The SPOT requires a yearly subscription fee of $100 while the Fast Find PLB does not. Initial price difference is about $100.
My question is about RESPONSE TIME. I have heard that because of many, many false alarms, there is a deliberate and significant time lag between when a 406 signal is received and help is sent.
I wonder if response time might be shorter with the privately-run SPOT Messenger service.
Actual experience sought. Opinions also welcome.
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
I'm a big SPOT fan and haven't looked at the PLB. I don't know if there have been enough incidents yet to build a data base to assess response times. However, a big plus in my mind is the fact that SPOT alerts go not only to their response center but to the email and cell phones you have selected. That means that properly briefed friends ashore can proactively call the Coast Guard and say that they have been following you through the tracking function, know that you are sailing, know that you are not sending out a false alarm, and are sure that the distress call is real. If the USCG hears from someone like that at the same time as they hear from the SPOT call center in Texas, they may get SAR underway faster.
The ability to use the "Help" function to have your shore contacts send out a more flexible agency than the USCG is also a big plus in some situations. If it's a medical or mechanical issue, your boat may be saved by having a local harbormaster or SeaTow come than the Coast Guard. The USCG is apt to just evacuate you and leave your boat. They are in the business of saving lives; not property.
My "Help" message includes a link to a web page telling my shore contacts what to do and listing all the contact and vessel info they will need. Now, with smart phones, many people will be able to access that information even if they are not at home.
For deepwater voyages and to areas with poor sat phone coverage, you should still have a standard EPIRB. If the USCG hears from your shore contacts, the EPIRB, and the SPOT call center, they will be taking the call seriously a lot quicker than just an EPIRB alert.
pupluv
Nov 11, 2007
90
- - wilmington, ca
I wrote to the USCG asking whether there was in fact a delay between when an EPIRB signal is received and help is dispatched. The USCG says NO DELAY. Here's the letter:
PLB's are an excellent way to alert Search and Rescue (SAR) authorities of an emergency. Just as with VHF radios, the Coast Guard does receive a number of false alerts from these devices, but there is not a deliberate time delay from the Coast Guard when there is a known emergency. The system does have its limitations which can delay the emergency message from being forward to the Coast Guard, but understanding the system can eliminate much of that delay.
The 406 Satellite Emergency system uses two different satellite systems to "listen" for distress beacons.
-One Satellite system is the Low Earth Orbiting Satellite (LEO) which obits around the poles. This system uses Doppler to locate a beacon that has been activated. It can take up to 90 minutes for the satellite to pass over a beacon, and it usually requires two passes of the satellite for it to determine a position.
-The other Satellite system is a Geostationary system. The satellites in this system "hover" over a spot on the earth and can see approx 1/3 of the earth at a time. The GEO satellites are not able to use Doppler location processing since they have no relative motion between them and the emergency beacons. Therefore, they are not able to determine a location for a beacon. They can, however, provide immediate alerts. This is a valuable tool for SAR personnel since it allows them to begin their initial verification of the alert using the National 406 MHz Beacon Registration Database. Often this detective work yields a general location of the vessel or aircraft in distress and SAR assets can be readied or dispatched to that general area. Ideally, a LEO satellite will fly over the beacon within the next hour and calculate a Doppler location which will be given to the SAR personnel who may already be enroute.
How can you decrease the time for alerting SAR authorities you are in distress? Ensure your beacon is equipped with GPS. GPS equipped emergency beacons send the GPS position along with the distress alert when it is activated. The GEO satellites would receive the alert along with the position provided by the GPS in the beacon. The second thing that can be done to quicken the response time of SAR authorities is to properly register and keep up to date the registration for your beacon.
Two important considerations: First, a GPS-equipped beacon only works when the receiver has a clear view of the sky in order to permit the receiver to self-locate. Often times, conditions do not permit this which may either distort the positional accuracy or negate it altogether. Because of this, the 406 emergency System relies upon the Doppler locating effect as the primary means for locating a beacon. This process is able to overcome the limitations of a GPS unit and still generate a fairly accurate location...within a mile for positional accuracy. Secondly, the GEOSAR component only works if the beacon is registered with NOAA. Without registration, the RCCs are unable to react as quickly...and ultimately this may delay a SAR response should you be in an emergency. Keeping the beacon properly registered with NOAA at the National 406 MHz Registration Database can save valuable time during an actual emergency. There is even a comment section on the beacon registration site that allows you to put info such as, where you will be sailing, time you expect to be out, number of people on board, etc. This information is forwarded to SAR authorities when the beacon is activated.
Mar 20, 2004
1,746
Good point, Roger! I'm also a big spot fan, but we are also PLB and Epirb equipped; Escape has an EPIRB on board, but the fastfind PLB is standard deck crew gear for us. They are now on sale at Defender (and WM will match) for $210, and for that I'd carry both. The more means of communicating you have in an emergency, the better.
