Spontaneous combustion
I won't speak for @capta, however spontaneous combustion of oily rags is a concern. How do you clean up the engine room after changing to oil? Or bleeding the fuel lines. What about cleaning brushes after varnishing? Or oiling the teak?
Nov 6, 2006
10,118
Neighbor wife put a bunch of brush cleaning rags in their garbage cans next to their house. Next day at around 10 AM, I smelled smoke and found the can blazing and beginning to scorch the side of their house. I put it out; they were not home.
I am a bit sensitive since my house burned while I was on vacation in 2000.
certainly something to consider.
Dec 28, 2015
1,917
It only happens with catalyzing/oxidizing oils. Engine oil isn’t one. Catalyzing oils are ones that harden. Some mistakenly describe them as “drying oils” but they do not dry or evaporate. They harden through oxidation. Hydrocarbon oils/diesel do not self combust neither does solvents but if the proper oil is cleaned with a solvent the oxidation takes place a lot faster generating higher amounts of heat causing potential combustion if the situation is correct.
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
Cardinal rule has always been no rags, paper towels, brushes, etc etc that have been used with oils, varnish, fuel, etc are ever left onboard. I don’t know the chemistry of combustion, however, whenever I leave the boat, I’m carrying a trash bag if the project used such.
Apr 11, 2020
801
MacGregor 26s Scott's Landing, Grapevine TX
Thanks, capta!
It's not something we typically associate with sailing, but as dlochner alluded to, oily rags are common on some sailboats. Good thing to be mindful of.
Hey, here's a question: Which of the following two is more responsible for sailboat fires?
-Lightning strikes
-Onboard fires
I know which one I would lay my money on...
Mar 26, 2011
3,767
Corsair F-24 MK I Deale, MD
Electrical - more specifically, unfused battery cables, IMHO
The one fire I actually saw start was on a truck. The battery cable did have a fuse, but it chafed on the frame, no enough to blow the fuse, but enough to melt and ignite the fuel hose it shared a pass-through with. So add chafe protection.
I keep my shop waste in a steel drum with a lid. I keep all of the solvent-based materials (paint, spray, solvents, gas additives etc.) in very heavy steel cabinet that is closed. If I have solvent or paint-soaked rags from a project, they go outside on a concrete slab at least overnight. Fire risk, and it reduces solvent fume in the house.
I have witnessed several spontaneous combustion fires at work in several scenarios. Not common, but it does happen. Several were just used oil with no reactive oils.
Likes: Ward H
Another storage option is a covered metal garbage can filled with water.
Bob S
Sep 27, 2007
1,805
Beneteau 393 New Bedford, MA
This happed to a neighbor from fresh bark mulch. It was caught in time to prevent a disaster. Not just oily rags.
Dec 28, 2015
1,917
The oils will continue to oxidize once removed from the water and produce heat. Under special situations they can combust after they are removed from the water and placed in the garbage. . It’s safest to leave the rags out laid flat to allow them to dry and disipste the energy.
Dec 28, 2015
1,917
A common one is potting soil. It’s not soil, it’s compost materials. I’ve had several smoldering fires from it.
  • Wow
capta
Jun 4, 2009
4,958
Actually, it doesn't necessarily only happen with oils. Wet a cargo of coal and as it dries, poof. Many a ship has been lost that way. Other materials which could spontaneously combust;
  • Towels and linen, during laundering and drying.
  • Haystacks.
  • Green waste piles and compost.
  • A number of chemical substances, such as cellulose nitrate.
