K
Kevin W. Coffin
My wife and I recently purchased our first Hunter(actually November 25,2005) and the marine survey revealed a few problems. First and foremost is the 'Spongy Section' of deck. Just to clarify the reading of moisture was just a bit less than the rudder. The section is only about 1ft by 1ft and it appears as though there has been at least one attempt to fix it with the attachment of a vacuum in two spots. Obviously did not resolve the problem otherwise I would not be here. Any suggestions as to how to fix the problem before it grows? Also one of the deck plates that the spreader stay attaches to is leaking and the water is following the steel beam down int the salon and into the bilge. Any suggestions as to how to fix/ repair/ resolve this problem? Any advice for a 'NEW'(maybe I should say 'Green') Hunter owner? Thanks because I do have more questions to ask.
