My new-to-me 1974 Vega has spongy feel to in a front and back of the
cockpit sole/engine access cover. My guess is that some of the foam
core has broken down with use over time and some water has perhaps
invaded as well. I am concerned that with continued use, the upper
layer of fiberglass will continue to fail making repair more
difficult. What solution have folks found to work with this
situation? The teak grate looks like an expensive cover up. Do I cut
off the back side, grind out any foam core, then replace with plywood
and epoxy sandwiching it all back together again? Or, how about
fitting a piece of painted plywood? Just a couple of my thoughts. In
search of sound advice.
