split shaft coupling
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
Truckman
In mainsails directions he says not to hit the shaft towards the transmission when it is connected to the transmission, but in #4 he stated that you have to tap it home with a rubber mallet in order to get the shaft into the coupling. Is this a conflict and if not do I have to worry because I have a split coupling.
What brand of split coupling do you have?
paulj
:troll:
6,243
S2 9.2a Fairhope Al
Truckman
paulj
:troll:
i think he is saying hit the coupling on to the shaft not hit the shaft in to the coupling
Feb 8, 2014
1,300
Columbia 36 Muskegon
Don't tap on the output shaft of the transmission, in or out. That can damage the bearings. It's ok to tap the coupling onto the shaft, but don't beat on it. With a split coupling you can probably get out all the way on without much force.
