A
Anthony Bavuso
Has anyone else considering modifying the Hunter25.5's transom to allow for a split backstay as opposed to an offset single backstay?I am considering a split backstay for a few reasons. I am going to install a backstay tensioning system. I have looked at several options like the wichard inline tensioned and have concluded that the best and least expensive way is to use a block and tackle system. So my options with a block and tackle system are to use the single offset backstay as it exists now and put a block and tackle system inline with the single backstay. Or I could modify the boat and have a split backstay and employ a system that uses the block and tackle to pull the two split stays together which results in tensioning the stay.The advantage in my mind of having a split system is that your mast is not being held up solely by the Dacron line in the block and tackle as it would be with the inline block and tackle system. Where with the split system you still have wire rope holding up the mast in the event the Dacron line breaks.So has any one else considered converting their single backstay to a split system?
