I just purchased a SignetMarine MK 11 knotmeter (3-pin male plug). I'm planning on purchasing a replacement 3-wire SignetMarine transducer for it. The problem is that both have male plugs. I've contacted SignetMarine who suggested that a) They'll swag some kind of a plug to connect the two (no cost estimate), or b) I could directly splice the two. The problem is that, apparently, the third wire "doesn't do anything," but they ignored my questions as to the color of the individual wires I should be splicing.
On the flip side, the PO installed a 5-wire transome paddlewheel which does not have any plug and is not hooked up to anything. My understanding is that the sensor is likely a temp/speed combination. Is there a way to a) hook it up to my 3-wire knotmeter, and b) if there is, how to tell which wires are for the speed sensor?
Any ideas are appreciated.
