I have a couple of 12v DC Bora fans that I'm trying to install in the forward berth. I do not want to run dedicated line to fans so am trying to tie in to existing 12v DC lines in the area. There is a 12v DC CO monitor in berth with easy access and figured tying into it. The amperage rating for the CO monitor wiring is much higher than the fan. 1) can this be done with clean splice? 2) should I run an in-line fuse for the fan since higher amp rating on CO monitor? Any input would be appreciated.
