Splash Guard Solution
John
We finally made a galley splash guard to protect our H-356’s saloon cushions. I designed and installed a 36" x 7" clear 3/8" acrylic panel with 3" radius corners. You could go out to 48" and increase the height a bit, if you wish. Here is what I used: • 1 pr TACO 3" Chrome Plated Brass Shelf Brackets from West Marine • Assorted #8 SS oval head bolts & screws, locknuts, washers •3/8" Plexiglas from a local glass store with polished edges and drilled to match the brackets’ holes on 23-1/2" centers I removed the small panel in the seatback to gain access behind the sink and determined the bracket locations by feel. A small mirror is helpful. Installation possibilities are limited because of lack of clearance around the sink and interference from the wood braces connecting the countertop to the cabinetry. However, these were the only marine brackets I could find, so I worked around the limitations. First, I attached the Plexiglas to the brackets’ top holes using two 3/4" bolts, washers and locknuts. Then, using the brackets as templates hard against countertop molding, I easily drilled through the Corian countertop with a 3/16" HAND drill. Next, I bolted/screwed the two brackets to the countertop, using silicone for the three locations where washers and nuts wouldn’t fit. At my wife's insistance, I left the remaining bracket holes empty because they just meet the top of the curved molding. She was concerned that if I screwed anything through them, the molding would crack. You could silicone in two tiny #8 oval head screws for a more completed look. The results were effective and our total cost was less than $50.
C
Colin Cheetham
Splashguard
John, I like the look of the splashguard. Did you think of screwing the plexiglass to the moulding ie along the bottom of the pleiglass, instead of using brackets?? Must check the height of the moulding when I'm next on my boat. I just wondered if resting on the corian top and screwed into the moulding the plexiglass would have sufficient support?? BTW thanks a lot for adding ANOTHER job to my wife's list of 'extra's ' she wants me to do. Colin
John
Splashguard direct mount to molding
Colin, I did think about screwing directly into the countertop molding. However, this would place the Plexiglass on an angle which my wife was against. To mount it vertically, you'd need a matching wood filler to take up the space between the inside curve of the molding and the Plexi. The molding isn't very thick and I was concerned about the screws coming through, if you started from the Plexi side. You'd be better off bolting from the seatback side through holes in the molding plus filler with a washer and locknut on the Plexi side. Please note some alternative methods already posted on the Forum: routing a channel in the Corian and setting in the Plexi (looks elegant but I can't rout, can you?); or using bathroom glass shelf fixtures epoxied to the Corian and setting in the panel (looks elegant but is much more expensive, and it might be difficult to clean under the panel's bottom edge). Please note I placed two larger photos in an "article" on the H356 page. Link "36" is to a close-up of the installed bracket. Let us know what you come up with.
Rich Stidger
Nice looking installation
Congrats- nice job. There is nothing like an simple yet elegant solution to a problem that doesn't cost multiple boating units.....
