Tom M.
Peggie,This last weekend our head (the cheap Jabsco) started acting strange. First, after use it would make kindofa gurgling sound. Then later when I was pumping it, it spit back out the discharge in the bottom of the bowl! Yikes! That's not good. I was thinking that some valve in the pump is not sealing completely allowing air to back flow into the discharge. Shall I take the pump apart and attempt to clean the (I assume) flapper valves there? When we pumped out, I went into the head and pumped the bejeebers out of it on wet bowl, thinking that there may be some foreign material stuck in the works somewhere that got sucked in via the water intake. I hope that that would clear it but don't know if it did or not, will find out next weekend.Suggestions?Next year is a new Raritan PH II. BTW will the PH II have the same footprint as the Jabsco?As usual, thanks Peggie!Tom M.
