I recently purchased a 23.5 which in my opinion is one of the best boats out there no docking fees and can handle some waves here in FL. Great fuel economy, and I love to sail. But the boat came with a Asymmetrical spinnaker on board and as I looked about for the rigging I found a pole turns out to be a whisker pole about 10feet when long. Then as I looked for the uphaul and down haul rigging all I found was a rope with a small strap on the deck and in the middle forward was a pulley to attach to something then a clamp to attach to some thing else after hours of research found out that the spinnaker was Asymmetric. Now looking at the mast there was no halyard no turn blocks nothing to fly the sail just the trimming hardware I found on the deck. I have been researching for days now how the best way to run the halyard I have determined the best way is out side the mast in the 1.5inces above the forestay which is in the manual but several ? I have. What hardware blocks and such what size rigging 3/8 which the manual states or the 5/16 for the 26 hunter manual states what bridle should be attached to the mast and what swivel block is best for cruising and cost also what turning blocks should be used the part numbers for both manuals are discontinued then what should be attached to the base of mast to send the halyard line port then aft to the cleat on the house any good ideas or has someone done this and has part numbers
