Spinnaker Wenches
David Bryant
I have decided to add the spinnaker winches to my H320. I have never used a spinnaker before, I have two Lewmar 30s on the boat now. Will single speed Lewmars work for a spinnaker or should I get two more Lewmar 30s two speed? ( single speeds cheeper) Thanks, Dave Bryant
Ralph Johnstone
Spinnaker Wenches ...................
.......... now there's something I wouldn't mind having on my boat. I can see it now ..... blond on the starboard and redhead on the port. I wonder if they're listed in the West Marine catalogue. On a more serious note Dave, I know that for our '99 H310, Hunter does not advise using a spinnaker due to the lack of a backstay. Their recommendation is to use a gennaker for downwind. This may still be the case with your newer H320. Regards, s/v Island Hunter
A
Alan
WENCHES???????
I have two wenches on my Hunter 30. One is a 45 and the other is a 13. The main trouble is, is that the two of them do not work well together. Have been trying for several years to find a way to make the two work together. Have just about given up and decided that I should only take one of them sailing at a time. Does this sound like a good Quick Quizzes for our responses????
Jim Logan
Most important wench is the beer wench
If you have a good enough beer wench on your boat, you will not worry about flying the spinnaker and will find that your sailing is more pleasurable.
Bill O'Donovan
Don't need winches
Just attach heavy-duty blocks to the back rail (29.5s have rings already soldered on) and run the spin sheet back up to the main winch. Works fine, looks good, lots of fun.
