Spinnaker Pole
3
- - Marina del Rey, CA
Hi All, I'm setting up a 1979 Catalina 38 to fly a spinnaker and I have a pole but the bridal for the topping lift is missing. Does anyone know where I can find a spec for the length of the bridal? Thanks, Mitch
Ray Bowles
You'll probably copy a similar rig locally.
Mitch, The quickest way is to either find a boat in your marina with a similar set-up and copy it or start with a good picture and work off it. It doesn't matter if it's not the same make & model as your boat as long as it's similar is pole size. There all different and that's what we did with our IP 38 and you adjust from there. Then you adjust it at the dock. Ray
