Ray
All, Last year we had a good discussion about where to put the spinnaker pole ring and I appreciate the advice. I actually used my spinnaker pole last fall before I pulled the boat and with the genoa on a downwind run it was fantastic. This year I am trying to finish up my install with a dedicated line to haul up and support the pole when I am flying it. I was going to use a Harken Carbo block (I just like them) on the mast with a cleat mounted lower on the mast to tie it off, but then started thinking about the fact I had an unused clutch and path back to my cockpit on the port side which would allow me to control the line from the cockpit. Two big problems are that I need to add an extra block at the base of the mast where the attachment points are on the mast base and I am worried that the line would not be real clean (i.e. the line would tend to ride against the mast). So far looking online I have not found the exact Garhauer blocks that are installed there either (might have to break down and call Catalina). Has anyone done anything similar, and what did you do? Thanks Ray
