Spinnaker on a H260
Jeff Anderson
Anyone ever tried installing a spinnaker on a H260. If so, how did you do it? Any recommendations would be great! Thanks, Jeff
G
George Henry
Been there
See photo forum I posted on spinnaker halyard and bow roller. Installed spin halyard per H26 manual. Used u bolt on bow roller for tack line. Has worked well, hope this helps.
Dave Condon
Halyard
Jeff; Look above and see if there is an extra roller above the forestay for a spinnaker halyard. If not, please advise and I will tell you where to get that part. Placement of another rope clutch is easy. You have a thick aluminium plate underneath the deck; therefore, drill and tap. Use small bit first to make sure you get metal shavings and use 5200 for selant. Crazy Dave
