My 2000 Beneteau 311 has a spinnaker halyard that exits the mast just above the top of the forestay. (This boat is fractionally rigged, but the forestay is only a foot or two or so below the top of the mast. Please see the attached pictures (the top of the mast is to the left). I believe the fittings and arrangement are identical on the Beneteau 323. As can be seen from the pictures, the red spinnaker halyard tends to bind on the top of the jib roller furling gear as the line is pulled to port or starboard, which is almost always the case when raising or lowering the spinnaker. The halyard rubbing hard against the narrow opening in the mast also seems likely to chaff during a long sail.
I was thinking of adding a ring or bail just above the sheave for the halyard, like the rings used to attach a spinnaker pole to the mast (nearer the bottom of course). To that ring I would add a swiveling block to lead the halyard away from the mast and inch or two and give the halyard some clearance from the forestay and roller furling gear. But this approach seems a little makeshift and I am hoping members of this forum have already come up with or know of better solutions to this problem. What ideas do you have?
Just for fun I added the last picture. It shows my asymmetrical spinnaker in use during a singlehanded race on the western end of Lake Erie two summers ago. You can't see the top of the spinnaker in this picture, but you can see that the spinnaker is pulled pretty hard to the side when reaching (above 90 deg in this case).
