Had a good sail Sunday but an issue arose that I would appreciate advice on. I had the asymmetrical up on a near beam reach (or at least the apparent wind made it appear so). The breeze increased until the boat was well over on her beam, and the wind had risen pretty quickly. I could not turn the boat downwind with the tiller, actually I thought I might break the tiller with the force I was applying. When I eased the mainsheet, thinking the spinnaker would push the bow downwind as the pressure on the main eased, she instead shot up into the wind, and so I did not blow the vang. I considered easing the spinnaker sheet but the boat was so far over that I thought I might drive the bow under if she turned without coming up first, and because easing the mainsheet gave me a reaction I didn't expect, I was reluctant to mess with the spin sheet. To get out of it I re-hoisted the jib which stole the air from the spinnaker and then took that sail down, but, and this is what I would like to know before I get into that spot again. Had I eased out the spinnaker sheet would the boat have come back up under control or, because the belly of the sail is so high would I need to let the spinnaker flog to spill wind? That seems risky too. Easing the mainsheet seemed to make things worse, though I don't understand why. Should I have blown the vang? If I allowed the boat to climb into the wind the curl crumpled and the spinnaker was out of control so that was not an option. Thanks
Craig Tern #1519
Craig Tern #1519
