Spinnaker Attachment To Mast
1
2 MKIII 30 ITHACA, NY
i HAVE A 1985 NEWPORT mkIII 30 AND NEED TO KNOW EXACTLY WHAT HARDWARE i NEED TO ATTACH TO MAST FOR SPINNAKER, THEN i WILL ATTACH BLOCK. THANKS DONNA
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
Um, for an asymmetrical spinnaker you just need a halyard at the top of the mast (so, yes, a block or sheave).
For a symmetrical spinnaker you will also need a topping lift to hold up the spin pole (so, another block a bit above the spreaders). The pole also needs a way to attach to the mast so a track with an adjustable eye or is advisable. There is of course the pole itself.
I suggest that you find another similar size boat that does fly a spin and have a look at the hardware they use before adding stuff to your mast.
Good luck.
Jun 7, 2007
515
Hunter 320 Williamsburg
Here’s an easy-to-make bowsprit, seats in the anchor locker.
This will throw the spin ahead of the main, less blanketing.
Tack line and 2 sheets permanently deployed for quick setup.
(Note that the link here has 2 pages of pix and directions.)
Typo correction: Eyelet should be 3/8 inch.
http://www.sailboatowners.com/bowsprit.doc
Joe
Jun 1, 2004
8,339
