Spinlock Clutch Bolt length
Apr 28, 2014
11
Hunter 340 Milford, CT
I have a 1998 Hunter 340 and will be adding another halyard. I need to add another clutch alongside the double Spinlock XA already on the boat. I understand there is a metal backing plate already fixed into the deck and I should be able to tap into it with the screws.
Does anyone know how long the screws should be? I don't want to drill too deep or install screws that are too long and go through the headliner.
Thanks
Apr 28, 2014
11
Thanks for your suggestion. I was trying to avoid removing bedded hardware as it sometimes doesn't go well. Guess I'll take that route as it may be easier in the end.
Oct 27, 2011
154
Hunter 1980 Hunter 30 San Diego, Mission Bay
Pulling a screw and measuring would be the best way. Hopefully you can do this without messing up the bedding. As a rough estimate, on my H30, the plate is about 3/4" below the surface of the deck. So you'd need a screw that protrudes about 1" from the bottom of the clutch. But your mileage may vary:)
