Spinnaker type
Hi Baja Bob, Welcome to the Doyle Sailmakers forum.A couple of things to consider first. Are you sailing with a crew of more than 2?, Is your boat set up with a spinnaker pole, topping lift and Foreguy?If not, you may want to favor an asymmetrical cruising Spinnaker such as the Doyle APC. The APC is designed for ease of handling and to be used without a spinnaker pole. The APC is effective to around 165% apparent wind angle. A symmetrical spinnaker with a pole can be sailed deeper down wind, but deeper isn't always faster or as safe. And Jibing the Symetrical is a bit more work for a shorthanded crew.With an APC asymmetrical cruising spinnaker, you can easily douse the sail, complete your jibe, and reset on the other side.
