Hi Mark:
My mast is up and won't be down any time soon (boat is in the water). However, here's the next best thing.
Go to the US Spars website:
http://www.usspars.com/
Use the pull-down menu to select manufacturer: Hunter
A new page will come up. Select Model: Hunter 23
Cllick the button that says "See Sections for this Model"
A new page will come up. Click the green link (Z190) to the right of "Conventional Section"
Line drawings of the three different Z-Spar masts for the H23 will appear. Look at the Z190 7/8. Type the number of the part you're seeking into the Item Identifier at the top of the page. A new web page showing a photo of the part and its price will appear.
Part No. 1051: The casting without sheaves or axles ("Combi triple Small")
Part No. 3283: the entire sheave exit/forestay attachment assembly
You can call US Spars and ask for further clarification if necessary.
For what they're asking, I'd get the entire assembly with sheaves. That way you know the sheaves and axles are good as the plastic sheaves tend to go bad after a while. All you have to do is drill out the old rivets, remove the old assembly, widen the opening and reeve the halyards. Make sure the jib halyard exits below the forestay and the spinnaker halyard exits above. Rivet the new assembly in place and you're there. It should only take a couple of hours.
Now for the halyard exit. You have a couple of options. If your mast step casting is the one with the main halyard exit at the bottom of the mast, it should have several openings for another sheave. Run the spinnaker halyard out the bottom of the mast and up through one of the slots, add the sheave and axle, rivet another cleat to the mast and you''re there. You won't even have to cut a slot in the mast. Of course, with this setup you have to pull UP to hoist the spinnaker, but if you have this mast step casting you're already used to doing that for the mainsail so it shouldn't be a problem.
If you don't have this mast step casting, you probably have to cut a new exit slot in the mast. That shouldn't be a big deal. Just be careful about where you cut the slot, because if iit's too close to the jib halyard exit you may create a weak point at which the mast could buckle. The Z190 section is very light.
US Spars also sells plastic halyard exits to prevent chafe. Good luck.
Peter
H23 "Raven"
