Paulj,I appears that the spinn halyard is routed externally on this mast.I would have expected that it would be routed from the deck in the mast and then exit the mast 2 feet below the jib halyard as see on the "Spin 2" picture.Steve
You appear to have an external spin halyard running through a block mounted on a bail above and in front of the headstay, where it should be. Other than possible interference with the wind sending unit it looks just fine.
