fill em now
I had an older Catalina 30 that had a lot of similar cracks in the cockpit area. I used a painted can opener punch which I sharpened on a grinder. Simply went along all of the hairline cracks to create a groove about 1/8" thick. then used white gelcoat filler to fill and sanded after it dried. It will take a couple of applications to fill the groove. Finally, I colour matched some gelcoat (no filler this time), and applied that with a putty knife, although is about the consistency of paint. Worked great. Took about a day to do. The important thing is take your time and because gel coat shrinks expect multiple coats.This fix is fine as long as the cracks are only cosmetic. This fix is a lot more involved if they go all the way through the gel coat.Happy Sailing,DougMokum II
