Speedometer Through-hull impeller
Dec 14, 2013
3
Catalina 30 MKIII Middle River, MD
Looking for a replacement impeller for a through-hul impeller.
The paddle wheel is from a Standard Communications Corp - SIA50
This for the stock speedometer on a Catalinia 30 - 1991.
SCC is out of business.
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
I'll be removing both through hulls from my 2001 Capri 22 this spring. Not sure if it's got the paddle wheel to match yours but it is a Standard Horizon. Might have some VC-17m on it but it's yours if you want it.
The old ST-100 display will stay in the cabin bulkhead until I figure out what to do with the big hole.
Dec 14, 2013
3
Horizon speedometer through-hull
This is great - If your unit does have a paddle wheel, we would appreciate having it.
Send it to the address below and I will send you postage plus $10. Please included your mailing address.
Regards,
Rodger Keller
623 Poets Way
Middletown, DE 19709
302 378 3947
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
I pulled two of said type of displays out of my boat and covered the holes in the bulkhead with these.
COVER PLATE 5-5/8"
http://amzn.com/B000N9O5T0
I put a little bedding around the edges primed and painted, they don't look half bad. Would be ok unpainted as well.
