Speed sensor through hull fitting on O'Day 25
26
I am restoring a '77 O 'Day 25 and come to a speed sensor fitting just aft of the keel. The gauge is all weathered out but the paddle wheel sensor looks like it was never used. Should I have the hole epoxied shut permanently?
geehaw
May 15, 2010
231
O-day 25 shoal keel Valdez
My feeling is if your not going to use it or it doesn't work why have a hole below the water line?
Erieau
Apr 3, 2009
209
Oday 25 Erieau
I closed mine off with glass/epoxy. The idea of having to insert/remove the transducer every time did not appeal to me.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
I'm not racing, and I can get speed from the GPS in my iPhone. Not sure why I'd want a speed transducer, given that technology at my fingertips.
I'd repair with epoxy and glass. You'll want to look up hull repairs on the google. You'll have to grind out the hole to feather it outwards, to make a nice taper to fill in with multiple pieces of fiberglass, generally biggest diameter down first and progressively smaller on top, and then grind smooth when cured.
Brian
Aug 4, 2009
204
Oday 25 Olympia
In tidal waters comparing the GPS and speedo will tell you to move over and get out of a foul current which can burn up a lot of gas. Tip: Never cross a rip line without checking if the current change is better or worse.
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
Is it necessary to have, no. Is it desierable to have, yes. Personally I will be purcasing a new unit and installing it this winter as my current one has reached the end of it's useful life. I find it important enough that I want to replace it instead of live off of GPS alone.
You need to know speed through the water as well as speed over ground if you want to really optimize sail trim and boat performance. On one tack you may be sailing parallel to the current, and the opposite tack be perpindicular to it, knowing what the current is doing allows you to sail the boat better (and pick the most favorable tack). GPS will only tell you that you are going slower, not tell you why. STW will tell you if you really are at hull speed or not, GPS SOG will never tell you that.
Also remember that charts and current predictions don't always give you enough information, and most importantly, they are predictions, not measurements, so they may be significantly wrong at times when the weather isn't playing nice.
As "Gudenuph" mentioned, it's really good to know when deciding what side of a rip line you want to be on (something no chart will tell you).
Oct 2, 2008
1,424
The moor gauges look nice and are easy to install.
Nov 9, 2012
2,500
Some great comments regarding speed measurements. I think I have it easy, sailing on a lake with no tides or currents :)
Brian
Nov 23, 2012
26
Thank you all for your comments . While preparing the bottom for barrier coating I had the hole glassed in. Now I no longer have that concern.
