Merrill Mant
Bill,Welcome to Hunter Owners.In July I replaced the original 1992 TriData unit for a new ST60 Tridata. I was required to haul the boat to replace both the speed/temp and depth transducers as the originals would not work with the new instrument. The new unit works well however I have noticed a substantial difference in the speed indication between a port and starboard tack of 1.5 knots. I have validated this with my GPS. I calibrated the unit with the GPS while motoring. The speed difference appears to be almost entirely skewed to one tack. The only thing that I suspect is that despite the best efforts at aligning the paddlewheel throughhull parallel to the boats centerline, it is not aligned correctly. Would you concurr?The location of the transducers is correct as far as the recommended positions supplied, ahead of the keel, flat section of the hull slightly to port of the centerline.The boat is a 1992 Hunter 335Thanks in advance for your assistance.Merrill
