Transducer on my 1985 lancer 30 is located aft of the rear bunk, open
access hatch, it is located immediately to starboard...when my transducer failed some years ago, rather than wrestle it out of a
tight location, I installed one inside the hull using silicone close to
the original. Still going strong...if you want specifics let me know.
Paddlewheel on my boat is located in the bilge port side, BobM is
right on they foul easily...but easily cleaned. You should have a plug
that came with the boat, if not I have cleaned mine many times by just removing it, spining it and let the water rushing in finish rinsing it as I
fumbled to put it back. In either case don't forget to replace the pin
holding it in. If you don't have to do the firedrill and have the plug
you can put a little anti fouling paint on the paddlewheel and I use a
little vaseline in the barrel on the o rings. Or clean it from the outside
when cleaning your bottom. Seems odd they both stopped at the same time and you still have power to the units? Good luck.. Hugo
