First 42 prop
Have an '84 First 42. Mine has same rig & keel config as yours, Perkins 50 and Hurth tranny with 2:1 reduc. Had a Gori two blade folder on for several years with good results. Put on a Australian SS Slipsteam two blade folder two seasons ago and had a serious problem this season: the poly cushion disintegrated and jammed the blade gearing in a partially opened position, a situation I did not discover until boat was hauled. My choice for the best prop would now be either the Gori THREE blade folder or Maxprop folder if you budget allowed. I am now corresponding with Seahawk PTY in Australia seeking resolution of what I deem a bad design.
