Specifications 31H
Margaritaville
in the specs it says there are two different drafts 4' and 5.5', displcements 9900lbs and 9700lbs, and ballasts 4200lbs and 4000lbs. are there two different mast heights as well? Years Built 83-87 LOA 31' 4 in LWL 26' 3 in Beam 10' 11 in Draft 4' / 5' 6" in Displacement 9900 lbs / 9700 lbs Ballast 4200 lbs / 4000 lbs Sail Area 458 sq ft Mast Height 47' 4 in
Dec 2, 1999
15,184
I think the rigs are the same.
I think that both of the rigs for the shoal & deep draft are the same.
Margaritaville
Top Heavy?
Wow with 200 pounds less in the keel I would think the Shoal draft version would be a bit more top heavy.
Mac Lindsay
H31 keel
the 1983-87 H31 came with a shoal or deep keel. The ballast in the short keel is 200 pounds more than the deep keel. The length of the shallow draft keel is longer at the keel stub than the deep draft. The designer, Cortland Steck, did this to give the shallow keel more "bite" to aid in the differance of the draft when sailing to windward. All other specs are the same including mast height and sail area. Mac.
