I am also working on my Tach. I found a new Yanmar tach the P.O. had purchased and installed. Did not work. I found that the new tach has 2 wires and the harness has 4. Plug is different also. I will figure it out eventualy.
My question is regarding the oil and water sensors. The boat has a water gauge (after market) that is stuck at 130 degrees. Can the engine sender still be used and install an automotive gauge. Most gauges come with their own sender. Do I have to use it and will it fit??
Also, can a oil gauge ( what should I use : pressure or Temp??) be installed using the existing sensor or a new sensor is needed to match the new gauge??
Can these gauges be installed and still retain the idiot lights?? Should they gauges be wired before the lights??
I hope I make sens.
Thanks in advance.
Jose
I hope I make sens.
Thanks in advance.
Jose
