I purchased my used Hunter 25, 12 years ago with a large space between the hull and keel. I filled the space with 5200, cranked the keel bolts the best I could and then matted and glassed the joint. I've had very little trouble with it since and have matted and glassed the joint three times since. I realized this creates an issue if I want to remove the keel however this is an old boat and I don't believe I'll ever spend the time and money to do so. Any thoughts on what I've done and issues with this solution?
