G
Gabriel
Hi:I need to install a Northstar T/H Depth Ducer 600W Nylon 50/200KHZ Low Profile [AA002107R] in my H-37 CutterI already have the Navman Trackfish 6600 working but need this sensor to use the sonar function.The ducer's housing is a 2-1/4" diameter and my question is:LOCATION ?I will lift the boat this weekend to replace the speed/temp ducer, I got a new one from Navman to replace the sensor only but I found the housing inside diameter is a little bigger so I need to replace the old housing and install the new one...So two reasons to lift the boat I have now.My concern is where to do the hole for the sonar's ducer.Any help will be appreciated!!Gabriel
