Something stupid
9
Hunter 23.5 Hollywood, Fl
Alright, so I have this sailboat that I bought recently, but I did something really stupid when I was out the other day. While bringing my jib in, after a wonderful day of sailing. My jib line ended up inside of the mast and was pulled all of the way out. Now she needs to be re-threaded from the top of the mast to the bottom. She's a trailer sailor, any ideas?:cry:
Rick D
Jun 14, 2008
7,206
What some riggers do is to tie a length of chain to the line and fish it out at the opening with a wire hook. In your case, if the mast is down, you would probably tilt it so that the chain can go downhill (I think?).
Jun 9, 2004
963
Hunter 40.5 Bayfield, WI
Gina-
Happens to all of us and usually more than once. My recommendation is the fish tape. I have rescued a number of lines with one. Good luck!
caguy
Sep 22, 2006
4,004
At school when they were installing underground conduit for the new computer system they took a cone attached to a light line and blew it through with compressed air, With the light line they were able to pull through a heavier messenger line. It was amazing just how far the were able to pull the fiber optics that way.
If you don't have a compressor you could to the same with a shop vac. and suck a wad of paper ttached to a kite string.
BTW if that doesn't work you can rend fish tapes from most tool rental stores.
Good luck.
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
$150.00 later (I'm too old to climb masts), my main halyard has a knot in the end with the tail doubled back on itself and seized to the standing part. It had a knot before but, when I was first sailing with my boys, the knot mysteriously disappeared after I said something like, "Untie the end of that rope."
