Lealea is developing a problem that I have never heard of before. Actually, I am not certain that it is a problem but here it is:
When we were in Port Townsend refitting after our first Pacific crossing from Hawaii, we took the mast down and left it for five months. During that time, the cabin overhead lifted away from the support beam on the port side. Just a bit, but enough to be noticeable. I figured it was because the pressure of the mast and rig had been removed and when we put the mast back up and tightened everything up again it would settle back into place.
Four years and another Pacific crossing later, the gap above the mast beam is even wider than before. Now you can actually see daylight between the beam and the overhead on the port side.
The mast is straight, the shrouds are properly tensioned and I would think there has been sufficient time for it to settle back down into position, but no. The vertical supports have not moved downward; there is still a good quarter of an inch between the bottom of the supports and the cabin sole on both sides.
Is this a problem? If it is, how do I fix it? I am really puzzled.
