This is a follow-up to an earlier discussion on sailing H23s to windward:I was out sailing yesterday under full main and 110 jib in near-ideal conditions. Wind was 12-15 kt with 10 to 15 degree shifts. There was a light chop and no current. The hull was clean but not scrubbed and my keel could use some fairing.With crew weight to windward, about 5 degrees of weather helm and playing the traveler and mainsheet in the gusts I could point up between 45 and 50 degrees of true wind (I measured headings on opposite tacks and divided by two) Boatspeeds measured with GPS were between 5.2 and 5.6 kt.Easing off slightly and sailing 50 to 55 deg. off the wind produced a surprisingly substantial jump in boatspeed (6.2 to 6.6 kt). The weather helm also dropped to almost zero. Earlier today, I did the math and here's what I found. Please correct me if I incorrectly defined the terms used in the discussion."Velocity made good" (VMG) is a measure of how effectively a boat works its way to windward. VMG is the speed over ground (SOG) times the cosine of the angle of the course over ground (COG) relative to the wind. SOG equals boatspeed only when there's no current. COG and heading are not the same, but since I was reading COG with the GPS (so it's actually "track" and not COG) I figured the leeway was automatically included. Again, please correct me if I'm wrong.When hard on the wind (45 to 50 deg.), my VMG ranged from 3.3 to 4.0 kt. while a tight close reach (50 to 55 deg.) yielded VMG from 3.6 to 4.2 kt. In other words, it appears that gains in boatspeed on a slightly lower course really do offset the slightly wider angle sailed to the wind (and the longer distance sailed over the ground). However, good pointing ability is still a viable option as long as you can maximimize the available boatspeed on that heading.Any thoughts or comments on this?PeterH23 "Raven"
