solo in my 310 - wind 15-20, gusts 25+...am I nuts?
Oct 17, 2011
221
Catalina 310 USA
I was originally planning on taking 2 days off and spending some solo time on the boat. Forecast is for sustained 15-20 knots with gusts touching 30 knots.
Any advice for a 310 sailer? I only have 1 reef point, but not sure if I will even attempt to sail given those high wind gust speeds....
Thoughts?
Matt
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
We've been out in these conditions many a time in our C310. Typically not by choice and not when we knew it was coming. We generally don't leave the docks if the conditions are sustained winds above 20 kts and/or gusts above 30 kts. The biggest reasons for this is typically docking. Prevailing winds push us off of our finder and into our neighbor's boat. So it can be really tricky to dock when the winds are above 20-25 kts. We have often said that we would go out more in those conditions if the boat was on a mooring. I did a post on here a couple of years ago about sailing in small craft advisories. I have since been out in them on a number of occasions.
As far as being out in those conditions, one memorable time we were out was on short cruise up to Salem, about 25 nm up the coast. The prediction was for 10-15 kts with gusts to 20 kts. Perfect! We headed out with our friends buddy boating in their O'Day 272. Once we cleared the harbor islands and hit the more open water it was blowing 25-30 kts. We hadn't gotten a real good handle on the slab reefing at that point and decided to just reef in the genny to almost nothing. She had really bad weather helm but we didn't get knocked down too bad. We averaged around 4.5 kts on that sail. This was four years ago and our first season with the C310.
This year we did our summer vacation cruise on the tail end of Hurricane Arthur. So most of that trip was winds in the 20-25 kts with some gusts as high as 45 kts. With the single reef in and about 80-100% of the jib area on the genny, we could sail pretty good in most of those conditions. And that included some Buzzards Bay chop days. The C310 does have some good weight to carry momentum through the chop while still getting up to speed quick enough. Sailing down Cape Cod Bay towards the Canal we had one reef in, about 110% of the jib area on the genny. The wind was about 18-22 kts with gusts to 26-28 kts and seas were about 2-4 foot rollers. We averaged around 6.2 kts on that sail with a max of 7.8 kts.
We have two reefs. In general the first reef goes in with sustained above 18 kts or gusts above 25 kts. The second reef goes in with sustained above 22 kts or gusts above 30 kts. The boat is setup to run two reefs. Have a second reef put in the sail it's not that expensive or order a new one with two reefs if it's that time.
As far as single handing, it's really the docking that's an issue. The C310 is setup very well for one person to sail her. The jib sheet winches can be reached from the helm. Either with the auto pilot or if you have her balanced you can leave the helm and go forward to deal with the main trim but it's a short trip. Most of the time I am sailing ours by myself. My Bride will be reading, napping or making us something to eat.
That all being said, these are probably not the conditions for you to go on your first solo sails. I might just hangout at the boat, get some projects done and enjoy the time off. There are often times, this past Saturday afternoon being one of them, that I just don't want to go out and "work" in those conditions. It's not relaxing when I am anxious about the conditions getting worse or about docking when we return. It's just not worth it for us to push those marginal days when we can just wait for a good one.
Good luck and fair winds,
Jesse
Oct 17, 2011
221
Catalina 310 USA
thanks for the insight. I might just go out and cruise around with the motor. Would the boat be very out of balance if I only use about 75% of the genoa, and NO MAIN?
Regarding docking - I rig up a "self docking system" when I am solo. Essentially it is a line from the piling located halfway in my slip that leads across to the corner of the finger pier and main dock. Coming in bow first, it acts like a cradle and pins the bow against the finger pier. The pilings in my slip are less than 12 inchers wider than the boat, on either side, so once I am "in", there is not much room for the boat to go any where. I highlighted the line in YELLOW in the attached pic.
weinie
Sep 6, 2010
1,297
I'd go out in those winds in my 27... single reef in the main take some in on the 135 genoa until the clew was by the mast. Downwind, I'd let the genoa out. The 30kt gusts could be troublesome if the predicted 30 ends up more towards 35-40 though.
Oct 3, 2011
833
We have gone out and sailed in winds like that. I use the adage that it is better to reef at the dock than try "OUT THERE", and also safer. Our 310 is a very stable, well made and safe boat. I would reef the main and sail with the 135, you can always roll it up alittle if it gets crazy. On The Great Lakes,especially Erie where we sail, because Erie is the shallowest of the great lakes we get short Steep waves and the lake gets Choppy, so unlike the ocean which is a slow rise wave ours get big,choppy,quick! So we need to power through them and keep the boat moving, so we use both sails.
It is always better to have the experience and know how to deal with it than not.
