Execllent Purchase
James,The O'Day 26 is an execllent boat. It was only produced for three years and only about 85 were made. Looking at the production run numbers, I can only assume that the 26 was dropped to concentrate on the 280. As was mentioned before, check the chainplate area, also check the turnbuckles. Being the size that they are, they are easy to bend if they get out of line when stepping the mast. One other area that I have found on my boat that will be changed soon is the the ice box draines into the bilge, not overboard. I plan on connecting it to the galley sink drain this fall.The 26 is quick and responsive to the tiller, feels very solid with the stub keel. If the boat that you are looking at get a clean survey, you will be very pleased with it.Ben AllenMontgomery, AL"Wahoo"1985 O'Day 26
