I was thinking about this during down times last night at work.
Wouldn't it be cool if you could build a 5 gallon or 3 gallon water heater that was heated by solar panel. It would be useful for smaller boats driven by outboards or boats without heat exchangers.
If you could design it with a temperature shut off so that it would be similar to a charge regulator. Once the desired temp is obtain the panel is turned off.
If it was insulated like the water tank in my boat, it would hold hot water long after dark. If I run my engine on my Catalina 30 it heats the water and the water stays hot for most of the night and into the next morning.
There are solar water heaters out there, but the design difference that I am thinking of is one where the solar panel is your typical electric panel. It is wired to the water heating element in the water tank. This way it may be smaller. It would be even better if you could run it off of a 20 Watt panel or something similar to that size. The key would be an efficient heating element that would get hot with very little power going into it. If the tank was 3 gallon it would be small enough to heat the water at a good rate, be easily installable in a small area.
Does anyone else think that this would be possible and a money making prospect?
