Maine Sail recently posted this about some panels:
"Keep in mind that many of the inexpensive Chinese panels use a junction box that is robot applied and simply uses friction between the j-box and the panels leads to make the connection. I've come across two now that would not pass any current. They read open circuit voltage but after a season in salt air they would not pass any current."
The panels we use have the connectors soldered to the cell leads, not just pressed together like MS referenced. That would be a good clue. Unfortunately, you probably won't know till you buy one and look at it.
