Solar panels
Ctskip
Sep 21, 2005
732
other 12 wet water
That'll do it. Thats just what I was looking for. Thank You
Allan12210,
The movement of air inside the cabin is important and it sounds as if you have solved this moving problem quite well. Thanks for the idea and the way you solved the problem. Sure beats $100's of dollars to do the same thing. I have more time than money these days. Thanks
Keep it up,
Ctskip
Ross
Jun 15, 2004
14,693
There are a few on this forum that seem to think a question should be asked until all other resources have been exhausted. I don't recall this question as having come up before and a search of the internet wouldn't much help. There is much information in the archives about solar panels but it tend toward the larger and more sophisticated installations. Just a little panel to keep your clock battery charged you won't find there. You newbies just ask away after you have at least done a superficial web search and learned some of the vocabulary. Please don't ask, "what is the rope that hangs from the long pole in the middle of the boat used for?"
You are certain to get yelled at for that.
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
Hey Ross,
Can i use that rope that hangs from the long pole in the middle of the boat to hoist my new VW solar panel?:)
Ross
Jun 15, 2004
14,693
Hey Ross,
You ought to use the stringy one that hangs from the sticks that poke out the sides of the tall pole. :D
