Hiee all,
While I may not get to launch this year the boat is nearly completed now. I am once again looking at the solar panel issue for charging our dual house bank. We have chosen to go with 2 150 ah batteries. All lighting is now LED for running,anchoring and cabin. Bilge pump draw of 5 amps when running its an Atwood 1100 gph and mercerator which draws 15 amps when running but will empty our tiny msd tank in a minute or less so total run time on that expected to be 3 minutes to empty and flush twice with clean water. Electronic nav is via a laptop running opencpn which draws 5 amps while the screen is active ie ON. The radio and compass both drawing less then an amp in standby and lighting.
Ok I will be going with a Kyocera 185 watt panel. It will be mounted on the stern pulpit railing.
The panel is about 60 inches long and 30 inches wide and slightly less then 2 inches deep. It will be mounted such that the long axis spans the transom and out to each side. The question being has anyone with a smaller boat 22 to 24 with this arrangement had any adverse handling due to the panel and its location and tilt angle?
Happy sailing,
Brina
Happy sailing,
Brina
