solar is good
Ive used solar on my boats and RVs for over 10 years now. If you are going to get one to put on the deck where you will need to step on it, you need to get the flexible kind made on plastic encapusated stainless steel. they are limited in power to just replacing a small amount of use in a whole day. And that's just for one battery. You need more power if you have more batteries or use a lot of amps per day. If you can figure a way to mount a rigid panel with glass topping, and aluminum frame, you can go much higher in amperage to seriously recharge what you might use in one day of sailing or overnighting. Get the largest you have room for. The larger the panel, the more amps it wil put out. The more amps or watts it's rated for, the less the cost per amp. With careful use, or for just one a day of sailing use, a 30 watt panel will do. For more extended use or day and night use, 40 or 50 is much better.With the higher wattage or amp panels you will need to also purchase a charge controller to avoid overcharging your battereis and to prevent backflow at night.Solar panel makers are experiencing such a world wide demand right now that they are in short supply except for huge arrays designed for home and business rooftops. smaller units are at premium prices. I've used UniSolar but I understand they are no longer making the flexible panesl you can walk on. Other brands may be available. I've been extremely pleased with the Kyocera 120 watt panels I have on my travel trailer, and the 50 watt panel for my boat. They provided the most watts for the dollar too.The only maintenance is just washing off the dust from the surface every few weeks. they will charge even with 4" of snow on top. I mounted mine with super exterior velcro, to the sliding hatch top. The boom only shades it for an hour a day. This summer I am constructing a stainless steel arch for the rear, to extend over the motor, beyhond the bimimi. There will be no shadow there, and it can also mount antennae, lights, etc. HOpe this helps.
