Dan Johnson
I have a small solar panel that has the 12 volt adapter plug on it. I have an adapter wired into my DC panel, that is controlled by a switch on the panel. My question is, do I need the switch in the on position for the solar panel to charge my battery, or will the battery discharge into the panel if this switch is on. Conversely if the switch is off, will I be able to charge the battery at all. Dan 'Unruly Julie'
