Solar Panel with 2 Batteries
7
- - Edgewater, MD
I love my solar panel. It was the one piece of equipment was I acquired and sold 2 different boats -- which each had one battery and outboard. Now I'm on an inboard for the first time, with dual batteries... and have NO idea how to hook it up. *o Do I choose just battery and ignore the other? Does it do both somehow? Do I put it one place and use the one / two / all selector? Thanks! Rick
Aug 9, 2005
772
Hunter 28.5 Palm Coast, FL
You have a lot of options.
I'm assuming your boat is aroung 23' - 27' and yout solar panel isn't too big. I'd hook it up to the house battery and give it a little extea charge. Make sure it has blocking diode so it doesn't discharge the battery at night.
Ken
Jun 1, 2004
1,182
Catalina 22 P. P. Y. C.
charge controller
You need a dual charge controller, Flexcharge makes a good dual for what your looking for. WM sells them now. I've had one for three years and so far (knock on wood) works like a charm. :)
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Solar
Kind of depends on the size panel you have. If it's a small one, I would use the battery selector switch, so I could charge either. If you leave the selector swith off when not on the boat, I would hook it in to the battery bank that the bilge pump is on. No need to spend the bucks for a dual controller if you have a small panel, as the smaller panels do good to keep one bank fully charged. Remember 25 watts, is only 2.5 amps approx. That won't do much for a more than one battery.
Nov 26, 2006
381
Hunter 31 1987 Fly Creek Marina Fairhope,AL.
solar panels / chargers
Rick, DEpending on the wattage of the panel, you might want to install it at the switcch and have the option of charging both or either battery. MY first reaction would be to install to the house battery only. @nd choice would be a 2 bank charge controller. since you had it for so long i presume you dont have or need a controler. im not the expert on solar but i bought my system here. They are very knowledgable and have years of experience. http://www.wholesalesolar.com/
May 11, 2004
149
Pearson 303 Lake Charlevoix
Casey has a good article
Rick, Don Casey has an entire book on sailboat electronics (which is great) but here's his short answer to your question. http://www.boatus.com/boattech/casey/30.htm Dave Crowley s/v Wind Dreamer II
W
Warren Milberg
I"m not sure what the...
... size of your solar panel is (i.e., output) nor what the demands are on your batteries so it's hard to provide specific advice. On my boat, for example, I have two Group 24 batteries (I like and use Group 24's because they are light, cheap, and typically last 5-7 yrs if I take care of them...). Although I have an onboard charger, I do not connect my boat to shore power for a variety of reasons, mostly have to do with my fear of ambient electricity in the water and so do not want to ground my boat. I have an ICP 5-watt solar panel for years and it seems to do what I want it to do quite well: maintain my two batteries. Since this is a small output panel, I only connect it directly to one battery at a time. I'm typically at the boat once or twice a week. Whenever I'm there, I switch the panel to the other battery. My demands for DC power, however, are minimal. I only use it to start the engine, run some basic electronics while sailing, and for a cabin light now and then. I typically use candles and oil lamps when at anchor. This system has worked for me, perhaps it will for you too. Good luck with your new inboard.
Brian
Two diodes will do the trick
Rick, I have two group 27 batteries and a 5 watt solar panel that are connected permantly thru a fuse and a seperate diode to each. Much as Don Casey reccomends. Have had this set up on my ODay 272LE inboard diesel for 5 years now works just great. "Hosanna" sits out on her mooring most of the week from May till November, no shore power, never had a battery problem yet. I will be replacing the batteries this season as more than 5 yrs is pushing it!!! Brian "Hosanna 272LE"
Brian
Solar Panel Bonus
An additional note. Leaving the solar panel connected at all times has a bonus inasmuch as it provides just enough power for the instruments and vhf on standby when under sail, thus saving the batteries some. Brian "Hosanna 272LE"
