Pete Shaw
Does anyone have experience wiring a solar panel to the 1, 2, both battery switch?I believe it should be connected to the common connection so as to charge both batteries,( and I intend to put a line fuse in after the charge controller also).by "common connection" I mean the one that also goes to the starter and alternatorThe solar panel is 10 watts and will just be used to keep 2 batteries up.It puts out .62 amps. My batteries are a 90 amp hr and a 80 amp hr.The contoller is rated at 7 amps and cuts in at 13 volts,and cuts out at 14.2 volts.Let me know what your experience has been with wiring a panel?Thanks,and fairwinds~~~~~~Pete "Eastern Sky" H280
