I've purchased a replacement for the solar panel that was standard equipment on my 1997 H 376. Before connecting the panel to the existing wiring installation of a regulator is required.
I finally found an H 376 manual, online, that had the solar panel connection, penciled in!
Hot side to the starter battery switch +, negative to the starter battery - (at the battery terminal.
At last!
Tim
At last!
Tim
