F
FrankM
I hope this is a simple question. I want to set up a solar panel to charge my batteries. The size, watts, amp usage, etc. is not important; it will be large enough that I will need a regulator. I have two batteries on a 1-2-both switch which I use for the house system. A third battery, on a separate on-off switch, is the starting battery. My question: how should I connect the solar panel to the batteries? I want all three to be charged. Should I run three separate cables, one to each battery positive-negative posts? Should I run cables to the 1-2-both and on-off switches? Should I use an ECHO charger from the house to the start battery? Should I install an isolator on-off switch in the solar cable when I am at dockside using the electic 3-phase battery charger? All the schematics that come with solar panel systems show a simple one panel to one battery hook up. I am confused how to properly connect my disparate system and appreciate any and all feedback. Thanks.
