Mega amps
The wattage you need depends on the amp hours you need. If "long term anchorage" means you'll be on the hook for days or weeks at a time, you will need to replenish your power daily from on-board sources.If you want something to produce enough charge to maintain your power needs, you first need to calculate your daily amp hour requirement. You say you want to take care of the "cooler, fans, other goodies." Depending on the the circumstances, that could easily mean a 50-100 amp-hour daily use.A solar panel will put out in bright direct sunshire, about one amp per 15 watts (15 watts / 15 volts = 1 amp). You might get 4-5 hours direct sunshine daily in the tropics; in Lake Erie maybe 3-4. That means for every 15 watts of solar panel, you can get about 4 amp hours per day. To get 50 amp hours a day to keep your batteries up with daily use, you're looking at at least 200 watts of panel. That's a lot of panels to put on a 26. And that's not counting extra for cloudy days. Your options are to use less power, or complement solar panels with alternate energy production -- generally that means a wind generator or high output alternators.
