Solar Panel Location 311/323
43
Beneteau 311 Cayman Islands
Hi Folks,
I'm looking for some good advice as to what seems to work best in terms of a permanently mounted location for a very small (approximately 14"X12" / 10 watt) solid solar panel on a 311/323 or even a 331.
I'd like to be able to easily remove the bimini, so that's not a great location for me.
Under the boom on the cabin top seems the best location, but seems like a lot of holes to drill, and wiring might be a challenge in the headliner?
Leads me to wonder about stern rail, but far enough from the ladder not to interfere.
Bimini/boom shade are not a concern - plenty of sun here, and this is just for a trickle charge. Anyone out there done this on a similar model with satisfactory results want to lend your thoughts?
Many thanks,
Mike
Feb 6, 1998
11,724
Hi Folks,
What do you expect from this panel? Is it a "maintainer" to keep your batteries that were at 100% state of charge, at 100% state of charge, or are you expecting to actually re-charge them?
Under the boom on the cabin top is one of the absolute worst locations for a solar panel, performance wise. Convenient, sure, but for performance terrible... Shading even a small portion of a panel can rather drastically cut your output. It does not matter how much sun you have, if you have shading. Keep in mind that even in the best conditions you'll only have about 5 hours of full output per day BUT this is ONLY if your panels are aimed at the sun and this 5 hour number is derrived from fixed shore based solar arays. On boats they usually sit flat and are not sun oriented for optima performance. I have yet to measure any boat panels at 5 hours of full rated output unless they were larger panels that could utilize the benefit of an MPPT controller.
For performance this is a MUCH better location but you're talking about a panel that puts out next to nothing to begin with. Keep in mind, the bimini can still shade this panel if it is in the arc but you will experience less shading than you will on the cabin top....
Even worse if it is just a "trickle charge" as the shading will take your output to a performance level so bad you may not even keep up with the natural self discharge rate. I have plenty of installations I've "fixed" where the net solar gain was zero..... Most of these were panels sub 15W that also had shading issues. Basically these owners paid for something, and then, got nothing...
Here's some math based on a 100Ah battery bank. I would guess yours is at least double that...
You're talking about a panel with roughly a 0.45A - 0.5A output.
You can plan on about 4-4.5 hours per day at full output (in PERFECT weather) with the panel flat.
MATH = 0.45A X 4.5 hours = 2 Ah's per day returned to the battery (in PERFECT weather)
So a 100Ah battery at 50% state of charge would take nearly 30 days (accounting for charge inefficiency and natural self discharge) to go from 50% to 100% with near perfect conditions.
To go from 80% state of charge, where your alternator leaves off, would take about 11+ days in perfect weather with NO shading. Any shading could easily turn this into 20 to 60 days, if at all, to get full....
If your bank is 200Ah it will take about 22 days + to go from 80% state of charge to 100% state of charge in perfect conditions with no shading..
I find the bare minimum for a 30+ foot boat, with a 30+ foot boat house bank, is around 30W panel....
If you can't go from 80% to 100% in a week then the cost, to benefit, is pretty negligible. If your not getting to full in 5-6 days you're still going to be suffering from bank sulfation and battery life issues.
Feb 6, 1998
11,724
This is something similar to Maine Sail, but these brackets make the panel completely removeable.
http://www.emarineinc.com/categories/Solar-Panels/Mounting-Kits/Rail-Mounting-Kits/
That panel removes in under a minute with just three screws, or about the same as the eMarine kit. You can also install it with quick disconnect pins as opposed to screws.
The two hing screws and the screw on the support leg and this panel is off. Of course you still need to address the wiring too.. The split rail clamps stay where they are....
I basically use the eMarine kit on my own boat, though I made it with the rail clamps long before eMarine began marketing theirs. I dislike the eMarine kit for stern push pits as it is hard to keep the sharp edges out of the cockpit. For davit mounts or bimini etc. they work great.. Ours is on Davits and the rail clamps allow me to angle it towards the sun for better performance.
Jan 18, 2010
43
Maine Sail,
Hugely helpful thoughts, thank you. I think I've learned more from your posts over the years than all the books I've read on sailing / diesel / boat electrics, and really appreciate it.
I think this has given me enough info to make a good decision. I'm now leaning toward a 20-30W panel on the rail. I just need to figure out how to make it work and not get in the way. I was hoping to create a 'leave it and forget it mount', but the options above may change my mind. And yes, my intent is mainly to maintain nearly fully charged batteries.
Mar 3, 2012
1
Benetau 311 Patras -Greece
Hi thear
I made constraction under the bimini on my 311 last year having a 80W panel and works o.k
