Excellent advice on testing it with a 2x4 shaded area. Now, if I could only get some sunshine to test it. Alaska has low solar angles in the winter so the idea of a pivoting array would be helpful. However, in the summer, the sun is up most of the time with high solar angles making the install  on the dodger acceptable. I may not always live in AK so adjustable arrays on the stern like you described may be best in the long run. The mast is currently down so getting a good measurement to clear the backstays would add guesswork into that equation. Also, since it is a smaller vessel I was trying to avoid the cluttered look and increased windage. Probably not a big concern but I really like clean lines.       From: "walt judy brown allore bestvega@... [AlbinVega]"
AlbinVega@yahoogroups.com To: "
AlbinVega@yahoogroups.com"
AlbinVega@yahoogroups.com  Sent: Sunday, January 8, 2017 7:35 AM Subject: Re: [AlbinVega] Solar panel install
Tim. Are you sure your panel will be affected by shading? On top of the dodger would probably be easiest. Put it on a meter and lay a 2x4 across it. When I bought Lyric, an early Series 1 she had no stern pulpit and the lifeline stanchions were only about
 16" high with a single lifeline. More decoration than function! After being knocked over the side when crew accidently gybed the boat they were replaced with homemade and taller stainless ones. After I moved in with Judy who worked for West Marine and got
 really  good discounts we again replaced them with stanchions from Schaefer. Anybody thinking about stanchion replacement is advised to beef up the underdeck support as you will increase leverage and strain on the base.I guess that is not really here or there with solar panel mounting so now I'll talk about that. I made a pulpit with Taco fittings and 1" stainless tubing. The taco fittings use set screws to secure the fittings to the tubing. If you want a more permanent
 mount drill a 3/16" hole through the fitting and the tube. Use a pop-rivet in the fitting instead of the screw. To get to the point I used fittings that left the tube open on top. I dropped short lengths of 7/8" tubing into the tubing. This allowed me to use
 longer tubing that could pivot on the short tubing. The longer tubing is where we mounted are panels. The first setup used tubing bent in to a 90 degree arc. Two 55 watt panels were attached with pivoting mounts to two separate tubes. This set up allowed us
 to point the panels more directly at the sun by being able to pivot up and down and fore and aft. It worked very well. Are longest period strictly on the panels was 19 days anchored at the entrance to Puerto Vallarta. We chatted on the VHF, listened to the
 stereo, watched a VCR movie nightly, ran our refrigeration and our water-maker daily.
We called Lyric bestvega for a reason . At the time we felt we were probably the best equipped Vega in the world. That West Marine discount really  helped. At the time it was 10% over cost. Sadly though we did weigh a lot more and sailing performance suffers
 from weight. Per Brohall said it best about equipping a Vega, "Keep her light".Now the panels mount to a single tube with a Taco T fitting on top. One panel to each side of the fitting. I'm thinking that you could use a Taco base for 7/8" tubing and connect the tubing to the rail on the pulpit and it would give you a place to mount
 it. Using a T fitting n the top of the tubing would allow you to put  mounts on each side of the panel. Hope this is helpful.        Walt, S/V Lyric #120
AlbinVega@yahoogroups.com AlbinVega@yahoogroups.com on behalf of Tim Malone alaskaflyfish@... [AlbinVega]
Sent: Saturday, January 7, 2017 11:05 PM
To:
 Wow, too bad we missed each other. I moved to Soldotna about 2 years ago from Fairbanks. I like Homer but am also looking for a more gentle climate down south. San Diego sounds nice and has good sailing too. Congrats on selling #1625. Mine is 1707 and just
 out of a year long refit and set to go in its permanent slip when the cold weather wears off. If you know somebody in Homer who could give me some pointers on sailing the Vega that would be helpful because my only experience is sailing my Force 5 dinghy. I
 hope you buy another boat. Cheers mate....
To:
Sent: Saturday, January 7, 2017 7:26 PM
Subject: RE: [AlbinVega] Solar panel install
Hello there Homer..... I lived all my life up there. Moved to San Diego a year ago, and bought a Vega. I bought 3 small panels, with nowhere to place them. Didn't want to place them under the boom, so the only
 decent place was from some kind of framework off the rear like you suggested.  Using the frame work from a Bimini might be the best option?
I had to answer because you're from Homer. Nice to hear about a Vega up there. I just sold mine yesterday....#1625. Good luck and have fun!!Sent via the Samsung Galaxy S7, an AT&T 4G LTE smartphone
